Unlock the Power of Wire EDM with BobCAD-CAM
Tailored Solutions for Every Wire EDM Challenge
Harness the power of BobCAD-CAM’s Wire EDM features: Precision-driven CAM wizards, automatic 4th-axis synchronization, and easy setup for precise results.
Customize settings specific to your Wire EDM needs and access an extensive postprocessor library for maximum performance.
Wire EDM Advancements with BobCAD-CAM
Functionalities that set our software apart:
Intuitive CAM wizards, simplifying complex projects from advanced shapes to 4th axis operations with precision and efficiency. Empowering you with clear, detailed imagery, it effortlessly streamlines sophisticated programming into an accessible and easy-to-use process for all users.
BobCAD-CAM automates four-axis wire part alignment, significantly reducing cutting programming time and enhancing precision cutting capabilities for complex projects. This innovative new feature ensures accurate cuts, consistent specifications, and optimal performance across various material types and intricate designs.
Effortlessly set synchronization lines and stop points for flawless 4th-axis programming, allowing for precise control and streamlined workflows. This advanced feature ensures a seamless transition from design to production, enhancing accuracy, reducing setup times, and optimizing resource allocation for improved productivity across various applications and industries.
Our comprehensive maintenance package includes access to a proven post library, along with personalized collaboration with our seasoned experts to fine-tune your output, ensuring peak machine performance and long-term reliability. This package also provides regular updates, preventive maintenance tips, and tailored support to help you maximize efficiency, reduce downtime, and achieve optimal results in every project.
Solidworks V12
BobCAM V12 is one of the most comprehensive CAM packages available for Solidworks users. It offers multi-axis milling, turning, wire EDM and more, as well as support for 3D geometry and 2D drawing files from Solidworks.
BobCAM offers different levels of integration with Solidworks including:
  • 2-5 Axis Milling
  • Lathe/Mill Turn
  • Wire EDM
This integrated software for Solidworks is designed to provide you with all the tools you need to create wonderful designs.
solidworks_v12
