Upgrade Your BobCAD-CAM for Faster, Smoother, Smarter Machining
Unlock Pro Power
Take your machining to the next level with BobCAD-CAM Pro
Eliminate tool vibration, reduce cycle times, and achieve flawless surface finishes — all with exclusive Pro features designed to supercharge your workflow.
⬇️ Keep Exploring the benefits⬇️
BobCAD-CAM V37
Why Go Pro?
Push Beyond the Limits of Express
BobCAD-CAM Pro isn’t just an upgrade — it’s a transformation. With powerful enhancements like Advanced Rough and Equidistant Feed Rate Control, you’ll machine faster, with better results, and less wear on your tools.
⬇️ 70% of our active users have have level up their software in the last year. This is why:⬇️
Advanced Rough Just Got Smarter
  • Overcome common issues with roughing toolpaths
  • Over Machining: Adds additional cuts in center areas to reduce vibration and improve finish
  • Remove Stock Pillars: Automatically isolates and removes leftover pillars using a spiral cut for smoother operation
  • Protect your tools and get more consistent material removal
“The spiral motion removes center pillars cleanly, reducing tool stress and increasing precision.”
Tame Tool Vibration. Cut with Confidence.
Speed Up Without Sacrificing Quality
  • Intelligent feed rate adjustments at corners and direction changes
  • Automatically slows down before tight areas — then speeds back up
  • Average feed rate nearly 2X faster without the risk of surface marks
  • Smoother finishes and extended tool life
“We used to run 54 IPM across the board. Now, we’re averaging 110 IPM — with even better finishes.”
Ready to Go Pro?
Start Machining Like a Pro — Today
