Unlock Perfect Finishes and Total Toolpath Control
Upgrade From Pro to Premium
BobCAD-CAM Mill 3 Axis Premium is the industry’s best 3D milling solution. If you’re using Pro, you’re doing good work — but Premium takes your finish quality, efficiency, and surface precision to a whole new level.
Less polishing, faster cycle times, and flawless parts — right out of the machine.
⬇️ Keep Exploring the benefits⬇️
Why Premium?
Flawless Finishes Start with Better Toolpaths
With Pro, your toolpaths are generated from an STL mesh. With Premium, we skip the mesh and machine directly from the surface — delivering unmatched finish quality and precision. Say goodbye to surface imperfections, extra polishing, and lost time.
⬇️ 70% of our active users have have level up their software in the last year. This is why:⬇️
Surface-Based Precision
Machine directly from CAD surfaces — no STL conversion needed
Preserve critical details, curves, and transitions
Achieve flawless finishes on complex and high-tolerance parts
Minimal to no hand-finishing required
“Pro gives you good. Premium gives you perfection.”
Smarter Toolpaths with Flowline & Morph
Flowline follows the natural direction of the surface with consistent cusp height
Morph Between Two Surfaces blends toolpaths for smooth transitions
Ideal for organic shapes and contoured parts
Eliminates unnecessary retractions and tool marks
Accelerated Machining with Barrel Tool Support
Use Barrel Mills (circle segment cutters) for larger step downs
Cut up to 3X faster without compromising surface finish
Increase tool contact area and machining efficiency
Reduce both cycle time and tool wear
Advanced Edge Control & Finishing Tools
Auto-deburr all part edges using Ball Mills, Lollipops, or Chamfer Tools
New Spiralize mode for rounded 3-axis edge breaks
Tool Contact Point Control gives you full precision on cutter engagement
Improve accuracy, reduce manual input, and save finishing time
Ready to Go Premium?
See the Premium advantage in one view
| Feature | Pro | Premium |
| STL Mesh Required | ✅ | ❌ |
| Surface Detail | Good | Excellent |
| Finish Quality | Consistent | Flawless |
| Programming Time | Moderate | Optimized |
| Polishing Required | Often | Minimal to None |
| Toolpath Flexibility | Standard | Advanced |
