Go Further with 5 Axis Premium
5 Axis Pro to Premium to Take on Complex Parts with Confidence
With BobCAD-CAM 5 Axis Premium, you get access to advanced multi-axis toolpaths, intelligent gouge checking, port machining, and powerful impeller operations — all designed to help you cut faster, smarter, and more accurately.
⬇️ Keep Exploring the benefits⬇️
“After upgrading to 5 Axis Premium, we’re finishing impellers in a single setup with better surface finish and half the programming time.”
— Chris M., CAM Programmer
70% of our active users have have level up their software in the last year.
[See Premium In Action → Watch Webinar Replay]
⬇️ Discover Key Benefits of 5 Axis Premium Over Pro:⬇️
Multi-Blade Machining (Exclusive)
Rough, finish, and polish impellers with full blade, hub, and fillet control.
Use toolpath patterns for quick duplication across complex geometries.
Port Machining (Exclusive)
Machine deep internal ports with confidence.
Intelligent tool movement avoids gouging and optimizes entry/exit.
Finish-Grade Precision
Achieve better finishes with intermediate steps, final passes, and adaptive cut control.
Get shop-ready G-code faster, with less post-processing.
Advanced Surface Toolpaths
Morphing, offset, and SWF options allow total control over tool motion.
Perfect for turbine blades, blisks, and other complex parts.
Need more reasons?
Here’s how 5 Axis Premium stacks up against Pro:
| Feature | 5 Axis Pro | 5 Axis Premium |
| Multi-Blade Machining | ❌ | ✅ |
| Port Machining | ❌ | ✅ |
| Toolpath Patterning (Rotate) | ✅ | ✅ |
| Surface Toolpaths (SWF, Morph) | ✅ | ✅ |
| Gouge Check Integration | ✅ | ✅ (Enhanced) |
| Tool Axis Control Limits | ✅ | ✅ |
| Hub & Fillet Finishing | ❌ | ✅ |
| Simulation + Backplot | ✅ | ✅ |
| Toolpath Editor | ✅ | ✅ |
| Advanced Feed Rate Options (MDI) | ✅ | ✅ |
