Why Upgrade?
Stop Indexing. Start Interpolating.
With 4th Axis Standard, you’re stuck roughing and finishing in indexed positions — repeating processes and extending machining time.
But with 4th Axis Pro, everything changes. Experience continuous tool movement across X, Y, Z, and A axes, giving you faster workflows and superior surface finishes.
⬇️ 70% of our active users have have level up their software in the last year. This is why:⬇️
What You Get with 4th Axis Pro
True 4-Axis Interpolation
Go Beyond 3+1 Machining
Simultaneous movement in X, Y, Z, and A axes
No more manual indexing or duplicated setup steps
Perfect for complex, contoured parts like helical gears
“We’re not just following the surface — we’re finishing it in one continuous, elegant motion.”
Cut Cycle Time, Not Corners
Rough and finish while rotating the part — no interruptions
Eliminate perpendicular tool paths that leave visible markings
Reduce finishing passes with more efficient stepovers
“Finishing used to take forever. Now, we’re cutting time and improving quality in the same process.”
Simplified, Professional Workflow
Define input, stepovers, allowances, and boundaries — just once
Automatic G-code generation for both roughing and finishing
Even complex parts programmed in minutes
“Roughing, finishing, and G-code — done in minutes. That’s 4th Axis Pro.”
