See What’s New in V38
Explore the Power of BobCAD-CAM’s Latest Version
Get more done in less time with V38’s streamlined workflows, enhanced toolpath control, and upgraded simulation.
cad-cam software
Upgrade Faster. Program Smarter.
Why Upgrade?
Our latest version delivers faster programming, smarter automation, and improved toolpath control.
With enhanced solid recognition, adaptive stepovers, and a new operation manager, V38 helps reduce setup time, minimize air cutting, and improve workflow efficiency across the board.
Key Upgrades at a Glance:
  • Improved solid model recognition
  • Adaptive stepover and depth control
  • Operation manager with tool-based organization
  • Edit toolpath directly
  • Advanced interface for Mill Pro toolpaths
Automatic Optimal Machining Angle in Slice Planar
Eliminate the need to manually set lace angles or create multiple operations. The new Optimal Machining Angle feature in BobCAD-CAM V38 automates angle adjustments within a single operation, adapting to surface direction for smoother, more efficient toolpaths.
Quick Surface Imprint to Wireframe
Easily imprint surfaces or solids onto wireframes in just a few clicks. Select your wireframe, choose the imprint direction and distance, and instantly generate clean, accurate results. No complex setup required.
Smooth Linking with Spline Moves
Premium toolpaths in BobCAD-CAM now support spline linking, allowing the tool to move smoothly across large gaps without retracting to clearance. This results in faster, more efficient motion and reduced air cutting between passes.
Add Chip Break to Turning Toolpaths
Easily apply chip break to any turning toolpath in BobCAD-CAM. Just select your chip break type, set the distance in the parameters, and you’re ready to go with full backplot support to visualize results instantly.
Adaptive Stepover for Rotary Toolpaths
Achieve consistent surface finishes on rotary parts with the new Adaptive Stepover option. The system automatically adjusts stepover values to follow surface geometry, eliminating uneven marks and improving finish quality.
Image to 3D Emboss Conversion
Convert any image into a 3D emboss using the BobCAD-CAM Art system. Save it as an STL for 3D printing or program it directly for CNC machining.
Use Solids as 3D Toolpath Boundaries
Now you can contain your toolpaths using solid models as 3D boundaries. Just select the desired surfaces in the Operation Stack, and the toolpath will automatically stay confined within those areas. No extra geometry needed.
Corner Slowdown Control for Toolpaths
Gain precise control over feedrates at corners with the new Corner Slowdown feature. Define the distance before the corner, set the reduction percentage, and apply smooth deceleration in customizable segments.
Edit Toolpath Directly for Precise Adjustments
Fix collisions or fine-tune motion with the new Edit Toolpath feature. Access options like move, trim, delete, or modify attributes without recalculating. Backplot instantly to verify changes.
Program Toolpaths Directly from STL Models
You can now create toolpaths directly from STL geometry in BobCAD-CAM. Just select the STL, set your parameters, and compute—see your changes update in real time.
Custom Step Downs with Enhanced Backplotting
Gain full control over your step-downs with the new Customize Steps feature. Define each depth manually, combine it with Minimize Retracts for efficient motion, extend toolpath entry, and preview everything instantly with the updated in-CAM backplot.
Keep Tool Down with Advanced Linking Options
Reduce unnecessary retractions by using the Advanced Interface to apply custom approach and linking options. Just set your preferences, compute, and keep the tool down for a smoother, more efficient path.
Advanced Interface for Mill Pro Toolpaths
All Mill Pro toolpaths now support the Advanced Interface, giving you detailed control over linking moves. Customize approach, gap handling, and transitions to minimize retractions and keep the tool down.
Toolpath Pattern by Point for Custom Placement
Use the Point option in Toolpath Pattern to move toolpaths precisely to multiple locations, even at different Z levels. Simply select the origin and target points, and BobCAD-CAM handles the rest for fast, flexible toolpath placement.
Trim to Stock in Lathe Operations
Now you can define custom stock shapes in lathe operations and activate Trim to Stock to cut only within the material. This reduces air cutting and boosts machining efficiency, especially during roughing.
Adaptive Stepover for Advanced Z-Level Finish
Advanced Z-Level Finish now supports adaptive stepover. Set minimum and maximum values, and the system adjusts automatically, using smaller stepovers only where needed to improve efficiency.
Automatic Solid Alignment
Quickly align imported solids to the origin in V38 without manual translation or rotation. Use the new Alignment feature to define geometry, set your origin, and match axes in seconds for a faster setup process.
Improved Solid Model Recognition
BobCAD-CAM now reads solid models more intelligently. Select directly from solids as the system detects edges, start points, and feature types. Hole recognition identifies diameter, depth, and more for faster programming.
New Operation Manager for Toolpath Organization
Easily organize and reorder toolpaths. Toolpaths are grouped by tool, so one change updates all related operations, saving time and reducing manual edits.
High-Speed Roughing for 4-Axis Roughing
The 4-Axis Roughing operation now supports High-Speed Roughing, enabling larger step-overs and improved tool life for more efficient machining.
Automatic Hole Recognition in SolidWorks
BobCAD-CAM for SolidWorks now detects and categorizes hole features like tap holes, chamfers, counterbores, and more, simplifying hole machining setup.
Extended Toolpath Control for Premium Toolpaths
Extend Premium Toolpaths in V38 using the new Extend parameter. Set a distance or percentage to push toolpaths beyond surface edges for smoother transitions and full coverage. Recompute and simulate in seconds.
Taper Pocketing from Wireframe
Create tapered pockets using just wireframe geometry. Set your desired taper angle in the pocket settings and recompute the toolpath. No solids or surfaces needed.
Silhouette Feature for Wireframe Creation
Quickly generate wireframe geometry from STL models using the new Silhouette feature. Use it to create solids, surfaces, or reference geometry for easier part programming and setup.
Save and Reuse Components in BobCAD-CAM
Create and save components from any part, native or imported. Easily organize, name, and reuse them in future projects with options to scale, position, and mirror for fast part setup.
Tool Support Added to Deep Boring Toolpath
The Deep Boring toolpath now supports multiple tool types. Select your preferred tool, recompute, and instantly view the results with backplot for quick verification.
New Wrap Geometry Tool
V38 adds a Wrap feature to project 2D wireframe onto cylinders. Set the angle, axis, and diameter to visualize geometry for rotary and 4-axis programming.
Ready to Experience the Difference?
Upgrade Today and Transform the Way You Work
Smarter automation and new machining strategies in BobCAD-CAM help you save time, reduce errors, and gain more control.
