Job Shops, Meet the CAD-CAM Software Built for You
Struggling with short runs, tight deadlines, or a variety of part types? BobCAD-CAM delivers fast, powerful CAD-CAM solutions for milling, turning, laser/plasma/waterjet, and multi-tasking machines—all in one place.
Whether you’re quoting rush jobs or programming complex parts, our software gives your job shop the speed, flexibility, and control you need.
cad-cam software
Video Library: 200+ machining tutorials
Quick‑Start PDFs: Printable setup sheets for drilling, profiling, surfacing, lathe.
Webinars: Monthly live sessions on high‑mix job‑shop workflows.
Your Business is Built on Agility. So Is Ours.
As a job shop, you take on a wide range of parts, materials, and deadlines. You don’t have time for complex software that slows you down. BobCAD-CAM offers an intuitive interface, powerful automation, and machine-specific solutions that help you win more work and deliver it faster.
Quick Stats:
  • < 2 min to program most drilling jobs with Hole Recognition
  • 30–70 % longer tool life using Advanced Roughing
  • 30–50 % faster surfacing cycles with Feed‑Rate Control
  • 15 %+ cut in annual tooling spend (profiling corner control)
4axis
One Platform, All the Tools You Need
From Milling to Mill Turn, We’ve Got Your Machines Covered
Cut everything from simple pockets to full 5-axis parts with dynamic strategies, advanced simulation, and time-saving features like Copy with Geometry.
What It Covers?
Pockets, contours, multi‑axis
Key Job‑Shop Features
  • Hole Recognition → drills in <2 min
  • Advanced Roughing → full‑depth trochoidal
  • Corner Slow‑Down & Minimize Retracts → less vibration & air‑cut
Drop in your model and generate mirror-smooth surfaces fast—Surfacing / 3-Axis Pro automates fine tool motion so you ship show-quality parts with virtually no hand finishing.
What It Covers?
Complex free‑form surfaces
  • Equidistance Feed‑Rate Control → 30‑50 % faster
  • Premium Surface Toolpaths (rename: Surface Finish Pro) → showroom‑quality finish
Quickly generate efficient toolpaths for OD/ID roughing, threading, grooving, and more. Trim toolpaths to stock, visualize with backplot, and save programming templates.
What It Covers?
OD/ID, threading, grooving
  • Compensation Toolpath keeps tools cutting
  • Chip Brake controls chips & extends life
  • Stock Trim cuts only where metal exists
  • Collision Check + Simulation
Support for complex multitasking machines with multiple turrets and spindles. Program faster with auto 3+2 roughing and new turn-mill operations.
What It Covers?
Multi‑turret, twin‑spindle
  • Auto 3+2 roughing
  • Turn‑mill ops
  • Sync manager
Program 2-5 axis profiles, automate common setups with job tree templates, and confirm your work with simulation and backplot tools.
What It Covers?
2‑5 Axis profiles
  • Job templates
  • Lead‑in/out automation
  • Simulation
Lathe Power for Job Shops
Most shops don’t just mill—they turn, too.
BobCAD-CAM’s lathe module brings the same smart automation and clear visualization you rely on for milling, streamlining roughing, finishing, and chip control before the first cut is made.
Feature Highlights
  • Compensation Toolpath – Follows part shape, keeps tool engaged, reduces cycle time.
  • Chip‑Brake – Break long chips on demand; safer runs, better finishes.
  • Stock Trim – Tell BobCAD the exact starting stock and it never cuts air.
  • Full Collision Check & Simulation – Spot insert or holder crashes virtually, not on the spindle.
Why Job Shops Choose BobCAD‑CAM
Your shop needs software that works as hard as you do—handling any mix of machines and materials with speed and precision.
  • Fast Toolpath Creation: Wizards + automation slash CAM time.
  • Easy to Learn & Use: Start cutting parts in days, not months.
  • Affordable & Flexible: Own it outright or choose a bundle that fits.
  • Real Support from Real Experts: Talk to machinists, not bots.
NEW
  • ROI You Can Measure: Cut tooling costs ≥ 15 % and recoup the software price in weeks.
  • Fewer Air Cuts, Longer Tool Life: Intelligent corner & retract control.
