Get More with V11 for SOLIDWORKS
Precision, Power and Performance
BobCAM for SOLIDWORKS supports better collaboration between engineering and manufacturing.
Check Out
the New V10
Fully-integrated SOLIDWORKS CAM to Help You Increase Production Speed and Manufacturing Revenue
Integrated CAM Software for SOLIDWORKS
2-5 Multi Axis Milling, Lathe / Mill Turn, Wire EDM, BobART
The new BobCAM for SOLIDWORKS V11 has a ton of new features and even enhancements to existing features! With the introduction of our Wire EDM module, we’re finally able to welcome our wire-friends to the BobCAM family. Craft your art projects more easily with the redefined workflow of the all new BobART user interface!
For those requesting more control of the operation posting order, including how toolpath patterns are posted, we decided to completely rethink this portion of the software and are introducing the new Operation Tree and Tool Tree to give you all the power and control you need. Oh, and we’ve got Finishing Spring Passes, brand new Leads with point picking and automatic lead from center options, and new features and enhancements in 2, 3, 4, and 5 Axis.
Whether you’re a new user, or already part of the family, this version is going to improve your work flow!
BobCAM SolidWorks Certified Gold Product
BobCAD-CAM has been a SOLIDWORKS software partner since 2006 and currently support SOLIDWORKS versions 2017 to the latest 2023 version. Our CAM integration is a direct add-in within SOLIDWORKS, which reduces data translation errors from design to manufacture.
Lead From Center
BobCAM - SolidWorks
By default the Lead from Center option allows you to utilize the center most positions of the created toolpath chains. In the past, creating leads that started/ended in the center of the chain could be a little more challenging than you would initially think. In fact, customers requesting the ability to do this easily is what led to these new lead types. No need to measure areas and calculate leads as these leads work on any shape to find the center-most point created by the chains.
Conical Machining
BobCAM - SolidWorks
When we came out with our 4 Axis Advanced Rough and 4 Axis Advanced Finish operations, it helped a lot in the machining of those shapes, but the toolpath wasn’t specialized for those shapes and there were still some drawbacks. Everything from the step downs to the limits is designed for cylindrical shapes. That meant conical floors would have steps and air cutting on the smaller end was impossible to remove with radial limits. These issues are now a thing of the past with the new Conical Machining option. Simply select the check box on the Patterns page, set the Cone Angle and now the entire toolpath is designed for that exact shape.
New Deburring Toolpath
BobCAM - SolidWorks
While the Deburring operation has always offered ways to specify the area to focus on by allowing selection of specific edges, check surfaces to avoid, and limiting the area by height, deburring only specific areas meant a lot of geometry selections and even adjustment of the operation settings. Now, hitting exactly what needs to be hit has never been easier. Simply select a solid, or solids from the graphics area and only the area inside of these solids will have the Deburring toolpath applied.
New CAM Tree Enhancements
BobCAM - SolidWorks
The Machining order dialog has been replaced by a complete Operation Tree which enhances the workflow in the software in many ways that were never possible. Once you’ve created your jobs in the CAM Tree, open the Tool Tree to see all your jobs, the tools in their tool crib, and which operations are assigned to each tool. For the first time ever, Mill and Lathe jobs also support MDI, or manual data input, which allows you to manually define machine movement as needed for your machining operations.
Surface Based Toolpaths
BobCAM - SolidWorks
Another tilting option is added to the arsenal of the Surface toolpath types with the new Tilted with fixed angle to surface normal option. The proper tool tilt is important in multi-axis machining, and while we have many options to choose from, including staying fixed to the surface normal, in the past you have not be able to adjust the tilt based on the surface normal. In this version though, you can simply select the option, choose your reference surface and set your angles.
5 Axis Milling
BobCAM - SolidWorks
The Undercut option in the Options page of the Advanced Z Level Finish now allows you to do undercutting when the operation is set to 5 Axis in the Tool Axis Control page. While the undercutting option has been a huge help when using undercutting tools in a 3 Axis operation, the undercut option has so far been unavailable when setting the operation to 5 Axis. Now, when set to 5 Axis, you can use Undercut with spherical tools by simply selecting one of the Checks on the Gouge Check page, and setting the Strategy to Tilt tool. You can even set an Extend undercut area value to have full control over exactly how much is machined.
Accelerate Model to Production At Lower Costs
V11 was updated to make physical production of SOLIDWORKS designs faster. BobCAM is fully-integrated with SOLIDWORKS, allowing for fewer errors in data translation than any other solution in the marketplace. With compatibility for over 100+ machines, BobCAM for SOLIDWORKS V11 is the ultimate CAM solution.
Available Languages
The BobCAM for SOLIDWORKS V11 release is available in the following languages: English, Spanish, German, Turkish and Japanese.
BobCAM - SolidWorks
New WireEDM Module for V11
2 Axis, 2 Axis with Taper, Land and Taper and 4 Axis Machining
For the first time ever, BobCAM for SOLIDWORKSĀ offers the Wire EDMĀ module!Ā The brand-new Wire EDM module supports 2 Axis, 2 Axis with Taper, Land and Taper, and 4 Axis machining to handle all your wirepath creation needs.
Run V11 Right Now!
You got this far, so just download and try it out directly in SOLIDWORKS. Once installed, you will be able to select BobCAM as an add-in and experiment with what you can do.
BobART Improvements
BobART has received a workflow overhaul to help you get the results you’re looking for quickly. We have improved the Raster to Vector dialogue by having it open directly in the Data Entry Manager. This allows you to view the image in the graphics area as you normally would. Zoom in, Pan, and even Rotate to put as much focus on the area whichever areas interest you the most!
Oh, and did we mention we now have a “Make as Solid”Ā option?Ā In the past, while you could do things to give a height to your model, extended walls were really the only thing added. You were still left with what was essentially a mesh surface draped down to the floor. Looking behind the model, as seen in the first image, it was apparent the mesh was not closed. With this new option, as you can see in the following image, the mesh is closed creating a water-tight mesh. This expands the possibilities of what can be done with your final model, and we’ve even added unit options allowing you to specify the units to use when exporting STLĀ Components!
CNC Programming
Speed up your CNC Programming Success with BobCAM for SOLIDWORKS V11
BobCAM - SolidWorks
Talk to a V11 CAD CAM specialist and discover how you can expedite machining of your SOLIDWORKS project.
BobCAM - SolidWorks
Try it Free for 30 Days
Your V10 software demo includes Mill, Lathe, Mill Turn, Router, Plasma, Laser, Water Jet, and Wire EDM.
Reduce Errors With Full Integration
Faster more accurate adjustments to toolpaths for quicker turnaround from design to engineering to manufacture. Less errors save time and materials, while SOLIDWORKS software familiarity improves learning curve.
Real People, Real Results
ā€œI’m impressed with the new deburring toolpath, how it breaks all my part edges with a single machining feature.ā€
Advantage Plan Member Since 2017, Lars Mommer | R&D Machining
CNC Milling
CNC Turning
CNC Routing
BobCAM for SOLIDWORKS V11 Now Available!
Schedule a demo by calling 877-262-2231
