See What’s New
Explore the Power of BobCAD-CAM’s Latest Version
Get more done in less time with V38’s streamlined workflows, enhanced toolpath control, and upgraded simulation.
cad-cam software
Upgrade Faster. Program Smarter.
Why Upgrade?
Our latest version delivers faster programming, smarter automation, improved simulation accuracy, and enhanced CAM organization. All designed to reduce setup time and boost machining precision.
From CAD design to multi-axis toolpath creation, every workflow in V38 has been refined for better speed, control, and usability.
Key Upgrades at a Glance:
  • Seamless Version Migration Utility to carry over settings and libraries
  • Smarter Hole Recognition & Expanded Feature Types
  • New Custom Roughing Tool Shapes for optimized material removal
  • Enhanced CAM Tree & Operation Management for faster navigation
  • Improved Simulation Accuracy for reliable toolpath validation
  • Flexible Post Processing Architecture with advanced NC editing tools
Basic CAD: Older vs. Latest Version
Creating and editing geometry is faster and more flexible in V37. Use parametric shapes, fillets, and booleans with ease, and quickly modify designs without redrawing from scratch.
Facing: V25 vs Latest
Say goodbye to manual stock setup and limited tool libraries. V37 brings integrated tool selection, adaptive roughing, and feed control to the forefront.
Lathe Edge Extraction: V28 vs Latest
Quickly extract wireframes from solids with smart tools like Spun Profile and Arc Fit, cutting setup time dramatically.
Lathe Programming: V28 vs Latest
More control, better visualization, chip breaking, and automatic stock trimming — V37’s lathe CAM offers a smarter experience start to finish.
Profile: Older vs Latest Interface
Simplified geometry selection, intelligent tool filtering, and advanced roughing options (zig-zag, s-links, corner slowdown) help reduce machining time and wear.
Facing: V31 vs Latest
Fewer clicks, more automation. V37 detects stock and setup automatically while giving you access to adaptive cutting and embedded MDI.
Profiling: V31 vs Latest
Toolpath control gets a huge upgrade: spring passes, keep-tool-down logic, zigzag options, and backplotting let you finish faster with better results.
Pocketing: V31 vs Latest
Detect open edges from solids automatically, add draft angles easily, and enjoy faster computation time with adaptive engagement strategies.
Drilling Enhancements: V31 vs Latest
With Advanced Holes and auto-detection from solids, drilling is now data-rich, precise, and much faster to set up.
Programming from a Solid: Older vs. Latest Version
From automatic feature recognition to advanced feed strategies, V37 makes solid-based programming intuitive and far less manual than V31.
Ready to Experience the Difference?
Upgrade Today and Transform the Way You Work
From intelligent automation to powerful new machining strategies, the latest version of BobCAD-CAM is designed to save you time, reduce errors, and give you more control over your programming.
