BobCAD-CAM Premium
“Best 3D Milling Solution”
Check Out
the New V35
BobCAD-CAM V35 to Help You Increase Production Speed and Manufacturing Revenue
Better Finish | Reduce Polishing | Improved Accuracy
As the price of tools and material is through the roof, anything a machining shop can do to reduce these costs will save thousands of dollars.
BobCAD-CAM’s Mill 3 Axis Premium has the best toolpath in the industry, guaranteeing a perfect surface finish no matter the complexity of the part.
Whether you’re a new user, or already part of the family, this version is going to improve your work flow!
Barrel Tools
Cut your machining time down while improving your accuracy, thanks to a larger tool contact area per step down.
Ball Mills require smaller steps downs to achieve desired finish.
Barrel Mills (circle segment cutter)
Use larger step down to achieve desired finish.
Flowline
Follow the shape and direction of the surface while keeping a constant distance and cusp height.
Mill Pro Equidistant Offset
The go to strategy for complex surfaces, this mesh based toolpath creates a consistent finish.
Mill Premium FlowLine
Offers more control for accuracy while delivering a better finishing that requires minimal polishing if any at all.
Morph Between Two Surfaces
Create Toolpath will perfectly adapt to the selected surfaces, allowing the user to cut different surfaces with a uniform path.
Advanced Planner
Direction of toolpath based on a user defined angle.
Morph Between
Direction of toolpath follows and blends between surfaces.
Deburring
Automatically clean all the corners and edges of your part with just a few clicks. Use Ball Mills, lollipops, or chamfer tools to break 3 axis edges.
Use Ball Mills to Break 3 Axis Edges
Use Lollipops to Break Undercut Edges
Use Chamfer Tools to Break 3 Axis Edges
New Spiralize Round Edge 3 Axis Edge Breaks
New Tool Contact Point Control
Available Languages
The BobCAD-CAM V35 release is available in the following languages: English, Spanish, French, German, Turkish, Japanese, Korean, Czech, Portuguese, and Italian.
Call Us Now At 727-442-3554
Upgrade to Mill 3-Axis Premium and save with the new version’s special pricing.
Real People, Real Results
“I’m impressed with the new deburring toolpath, how it breaks all my part edges with a single machining feature.”
Advantage Plan Member Since 2017, Lars Mommer | R&D Machining
CNC Milling
CNC Turning
CNC Routing
BobCAD-CAM V35 Now Available!
Schedule a demo by calling 877-262-2231
