Better Finish | Reduce Polishing | Improved Accuracy
As the price of tools and material is through the roof, anything a machining shop can do to reduce these costs will save thousands of dollars.
BobCAD-CAM’s Mill 3 Axis Premium has the best toolpath in the industry, guaranteeing a perfect surface finish no matter the complexity of the part.
Whether you’re a new user, or already part of the family, this version is going to improve your work flow!
Barrel Tools
Cut your machining time down while improving your accuracy, thanks to a larger tool contact area per step down.
Flowline
Follow the shape and direction of the surface while keeping a constant distance and cusp height.
Morph Between Two Surfaces
Create Toolpath will perfectly adapt to the selected surfaces, allowing the user to cut different surfaces with a uniform path.
Deburring
Automatically clean all the corners and edges of your part with just a few clicks. Use Ball Mills, lollipops, or chamfer tools to break 3 axis edges.
Available Languages
The BobCAD-CAM V35 release is available in the following languages: English, Spanish, French, German, Turkish, Japanese, Korean, Czech, Portuguese, and Italian.
Real People, Real Results
“I’m impressed with the new deburring toolpath, how it breaks all my part edges with a single machining feature.”
–Advantage Plan Member Since 2017, Lars Mommer | R&D Machining
BobCAD-CAM V35 Now Available!
Schedule a demo by calling 877-262-2231
