Revolutionize CNC Workflow with Automatic 5-Axis Tilt
Eliminates collisions and improves quality
Automatic 5-Axis Tilt dynamically adjusts tool angles to eliminate collisions, even in challenging areas like walls and horizontal surfaces. It ensures precise cuts by maintaining safe distances, while its deviation analysis tool compares the cut geometry to the original model, guaranteeing quality.
cad-cam software
Perfect Finishes with Automatic Tilt in CNC Machining
Discover How Automatic 5-Axis Tilt Transforms Your Machining Process
Explore the Benefits of Automatic 5-Axis Tilt
Download Free Demo
The system dynamically adjusts tool angles to prevent the tool holder from contacting critical areas, reducing the risk of damage and extending tool life.
With detailed deviation analysis, it compares the cut geometry to the original model, ensuring exact tolerances and professional-quality finishes.
Automatic tilt allows 5-axis operations to integrate seamlessly with 3-axis strategies, maintaining simplicity in configuration.
Through dynamic angle adjustments and collision settings, the system ensures continuous workflow and reduces overall machining time.
Solidworks V13
BobCAM for SOLIDWORKS V13 delivers powerful, integrated CAM for 2-5 Axis Milling, Lathe/Mill Turn, and Wire EDM, all within the SOLIDWORKS environment. It supports both 3D models and 2D drawings for a seamless design-to-machining workflow.
V13 adds a Version Migration Utility, smarter Hole Recognition, Custom Roughing Tools, and improved Operation and Tool Trees. With features like Finishing Spring Passes and enhanced Advanced Leads, V13 boosts programming speed and machining precision.
SolidWorks V12
